kingneptune
Everything posted by kingneptune
  1. I work with soft leather and there are times when pieces do need to be separated and reglued. Been with Barge since 1978 and it's by far the best in that usage, easy to clean visible glue off, too.
  2. First, I started making custom moccasins in 1978 so my opinion is experienced-based. I have always used Barge Cement because I don't think anything else is better and my work requires a strong bond while I'm working on projects. The glue doesn't seem to be as good as it once was, you can no longer buy an 8 oz can which I prefer because the glue gets thick with use and age and thinning weakens the expected bond. I've tried other brands as options and found them all to be lacking. Recently bought a can of S-18. Like the other wannabe's it's not Barge but...it works well where a lesser bond is adequate and leaves almost no cruddy glue balls on the lid area even after weeks of use. It's cheaper, you can buy it in several sizes including 8 oz, it has a shorter pot life and it's still not Barge but might be a good option for some others.
  3. Thanks
  4. First pair I've made in 38 years...buffalo hide, elk and goat trim.
