Hi all,
I am hoping someone can help resolve this issue I am having with my Pfaff 1295 (pic attached) where I get the following symptoms:
After I stop sewing and I lift up the presser foot, it's difficult to pull the material away because there are 4 threads attached to the material I am sewing: 1 upper thread on top of the material and 3 threads on the bottom. The 3 threads on the bottom of the material are: 1 bobbin thread and 2 extra upper threads. All three threads come from below the needle plate. Note: I determined the source of the thread by using different colours on top and bottom to differentiate.
When I snip the 2 “extra” upper threads on the bottom of the material, it's actually only 1 piece of thread that appears to be looped around inside the bobbin case. I simply pull it out with no resistance at all.
In general, the stitches look great on both top and bottom of the material with even, balanced stitches and no skipped stitches which leads me to believe that tension is set correctly. I have double checked the threading and also confirmed as well as thru Uwe Grosse’s video for his Pfaff 1295 (thank you @Uwe, great video) that the machine is threaded correctly and the bobbin is wound properly. I have installed new needle (System 134-35, tried both size 120/19 and size 130/21) with #69 bonded nylon thread. Also, I pull the material to the back when I remove the material after I am done sewing. I also have a synchronizer installed which is set such that the needle stops in the fully up position.
Thanks in advance for any guidance in resolving this issue:
p.s. Also, does anyone have a pdf copy of the operating and parts manuals for this generation of the pfaff 1295? I have found manuals for the current generation only.
