ct701996
Posts posted by ct701996
  1. you might already know this but ray holes makes some stuff called rawhide cream u can use that stuff but it might be a little expensive, also you dont necesarly need animal fat, just take ivory soap and scrape it, possibly with a poatato peeler or something, and mix it wth some water over the stove, i have not made this stuff but the guy that taught me to braid uses it , i have a friend that makes a mix with snowseal and something else, ill get back to you with the mix
  2. no its not too bad, i have a long tapered spike i use, and i usually can get it all the way through, then i take out the spike and put in my 3/8 plug, the spike is a little larger than 3/8 so i have to hurry and put in the plug but i can usually get it done. i think the knots look better if you tie them before you put the plug in
  3. I normally use rawhide burners on my rawhide hondas, but recently i have been using plastic burners, Plastic burners are really the way to go, you get the weight of a rawhide honda with the speed of a plastic burner, and when the honda gets wet it doesnt get so sticky and slow, please tell me whatcha think
  4. it looks nice, there are just a couple things you could have done different, on the back jockeys it looks a little nicer if they are a little shorter than the skirts, , then on the fenders take the bottom of the fender all the way down through the stirrup back to the blevins buckles, then when you cut your ear on the seat cut it out higher out of the seat leather, you will have to put a plug in it but it will be covered by the binding, all in all it looks good, please dont take offense to the comment, im not that experinced myself but i know from experince i can see other peoples mistakes better than my own
  5. i havent been able to find any varnish that would stand up to a honda, seems like every time you rope something and the honda flexes the varnish starts coming off, if you guys find something that works better let me know :)
  6. if you try to make the cantle too much taller without the tree right there it will probably get floppy on the top, if you are completely rebuilding the saddle with a new seat cantle back and cantle filler you can just run those things up higher than you normally would, but remeber the taller you make the leather go up the more the leather will want to bend at the top of the cantle,
