AThousandRasps
Everything posted by AThousandRasps
  1. Immiketoo: Dang. I was hoping there would be a different answer. I use the black waterstain regularly, but I find the colors overall lacking (and I don't think they'll work in my mixture). But it's worth visiting them again to see what I can make work!
  2. Battlemunky: Not Youtube specifically, but I've Googled the problem on multiple occasions. So far nothing helpful. Am I missing some crucial step?? VabaX: Yeah. The pieces don't get darker. They actually get a little lighter. Most recently I did a suit of armor wherein the green faded, so I airbrushed a light coat of green back on. That was just Angelus green mixed with a bit of rubbing alcohol (with Resolene on top), no Eco Flo. It faded in a single weekend of indirect sun. I guess I will have to switch to Fiebings dyes. They seem to fade a little less, but I did put out a test piece that showed visible fading in 3 hours of direct sun. That doesn't seem great. If no one else is having this problem it means I'm doing something wrong, but what?
  3. I have done tests with just the pure dyes and they also fade. Both Angelus and Fiebings. I doubt the stain is changing the chemical makeup of the dye. If you have a suggestion for an alternative base, lay it on me, but nothing else I've found gives me the right color and consistency. A long time ago I tried to use Fiebings antique pastes but they all left a chalky residue.
  4. Hello everyone! I currently make blue, green, and purple antiques by mixing Angelus dyes into Eco-Flo Smoke Black hilighter. (I have tried mixing them into Fiebing's neutral antique paste also, but that leaves this horrible chalky finish.) The effect is lovely, but lately I've noticed some terrible fading. The kicker was when a suit of armor I made faded from green to brown while NOT in direct sunlight! I've tried using the Fiebings alcohol dyes instead of Angelus but they seem to be fading as well when left out in the sun. Do alcohol based dyes always fade with exposure to UV radiation, or is there something I can do to prevent it? I have tried Meguiar's gold class conditioner (has a UV blocker in it, supposedly) but it didn't help. What bright-colored dyes or stains do you know of that behave better in the sun?
  5. I have a project that I stained with eco flo black waterstain and painted parts of with acrylic paint. Does anyone have experience removing either of those? I was going to try denatured alcohol, maybe lacquer thinner if that doesn't work, but I appreciate any advice. The piece also has a resolene finish but I assume whatever I use to strip will get rid of that. I also know that in any case I will have to condition thoroughly after!
