telcelsmx
Everything posted by telcelsmx
  1. Curious if anyone can help figure out what model this is seems industrial bc of the big motor but it might of been adapted since machine looks older and small https://ibb.co/gBBAFz https://ibb.co/fXq4az
  2. Hello everyone sorry to zombie up this thread but i like how pattern was transfered from soft leather, i wanna get my technique down to try with a soft stamp.. A coin with lame Id like to ask how long should i wet leather? Why is hot stamping sometimes done what does it actually do? Whats the difference between solder stamping with low hand pressure and a press? I plan on a c clamp for now but just trying to know when to use what. Also i read about transfer foil?for coloring the final pattern (not for the initial guide tracing)? I thought heat embossing was to darken burn the deeper pattern grooves so again confused. Also if you have a curved pattern you like (a buckle). How would you transfer that? Im amazed how well soft leather on leather copied. Im thinking of adding either floor mat foam or wood in middle part. About how much pressure do you want? Im using a clamp but saw many dislike hand stamping.
