CelticPrint
  • Content Count
    57
Everything posted by CelticPrint
  1. Saddlebags the first project is just a coin purse the size of a tribal seed bag. It is for my mother in law that refuses to move out of the old neighborhood. If someone mugs her I want it to tear off rather than dislocate her neck. Other projects would be the hammer loop for my revolver holster, I want it to stay in place if I bend the wrong way but if I pulled with let's say 35 plus lbs of force have it pop free. I've seen the hammer loops on a lot of threads here so for now I'm just wondering about the necklace purse, It is small enough that it only holds a few one dollar coins. She likes custom leather and likes to have a few back up dollars on hand for an emergency or if she is at a place that doesn't take cards.
  2. Has anyone used a breakaway device or knot for a project? I can think of a few projects I'd like to see hold up to light use but break free if it posed any danger to the person wearing it. I have the black snaps factory workers wear on their ID badges if I have to use them but I'm trying to keep plastic out of my projects. Has anyone tried an over hand knot on one end and a loop knot on the other end? I'm thinking find just the right tightness that it will hold a few pounds of pressure but slip the loop if caught in a machine. Maybe a wider strap with a slit in one end instead of loop? Also considering just making the lanyard thin enough that the leather would snap at the breaking strain. Thoughts?
  3. I'll have to try the deadblow hammer Northmount. When I'm was stamping with the wrong hammer I used to get a "double tap." The hammer would drive the stamp down, the stamp would push to it's limit and then the stamp would bounce up, shift ever so slightly just as the hammer fell back down. The double image of the stamp is no fun halfway through a project. Happened to me with thick leather on a rubber mat. Sometimes I just line up the stamp and push down with slow even force by hand, depends on the size of the piece and how many times I have to repeat a pattern. Otherwise I keep 2-3 different hammers and mallets lying around.
  4. Thank you and don't give up, time is just a learning experience. I'd like to hear others techniques, mediums or abrasives preferred, tools used and I didn't even touch on grind choice like hollow, straight or convex. I've tried everything from stones, to pastes to rouges. From hand work to Dremels to belt sanders. As of now I just use stones for rough work, paddles with different rouges or diamond pastes to finish and then horse hide strops with a bit of grease for honing. The only time I use power tools is if I'm roughing out a billet for a new project.
  5. The forum title says "share success" so I have some advice and examples that I'll throw out there and a few questions as well. Don't give up, not on time spent, your technique or even your choice of sharpening medium. You may be doing something right and throwing in the towel before you get the result you want or need. I started out by going for a Totin' Chip badge as a boy scout, had to re sharpen my chisels often as a carpenter and learned a lot about the need for stropping in Barbering school. I'm not the best but I have enough to experience to share a view. If you are new, don't rush to buy an expensive stone, it's easy to ruin a stone but also easy to get discouraged if you don't use it right. If all you have is a cheap stone, just apply some honing fluid, hold the angle you like and make circular motions over it until your bored and then do it for another 10-20 minutes after that. Switch directions periodically through and you'll have a cutting edge no matter what the grit. How long it will hold that edge really comes down to what you are cutting and how often you hone it. I've seen friends use a cement block for the rough work and switch to red brick for the finish and it still cut fine. Some stones don't like honing fluid, some prefer water, some can be used dry but if it's a wet stone and you don't keep the particles that come off of the blade flowing away from the stone it will ruin the stone so even if it's a cheap one or a "hand me down," know your stone. Intermediate, if you have a decent grasp of it now you can start using multiple mediums and move on to honing. One rough and one finish is fine to start but it will take a fair amount of time and effort if you jump from a low number to a high number in one session. Here you can move past circular motions and start using even strokes like you are trying to slice a thin layer of cheese while choosing a specific angle for a specific use. Some people use 10 swipes in one direction, then flip the blade and do 10 swipes in the opposing direction for the opposite side of the blade. Some people alternate for every swipe. Again, don't give up if it seems like it's not working it may just need more passes, especially depending on the steel used. Which brings me to steel. I don't really care for most stainless steel. It sharpens quickly and dulls even faster. On top of that, most stainless steel can not hold a razor edge for more than one cut through any medium or material. I say this because I shave with a straight edge razor and no matter how sharp a stainless straight edge feels it may shave hair off the back of your hand but it will not go through course beard hair. (We may be talking about leather work here but this is my best example of what sharp is.) High carbon steel is what I use for my chisels, kitchen knives and all my leather work blades. The key to keeping blades happy is honing. Some just call it "stropping" because a strop is used to hone a blade but you can hone on a kitchen steel or even the back of another knife. Honing is the straightening of the blades edge. As you cut and even as you sharpen the blades micro edge will curl. Longer blades will even wave in and out of alignment. Honing brings the blade back to where it should be. I hone on a strip of leather glued to a piece of hardwood, aka a paddle strop. I use backwards, even strokes pulling away from the blades edge. How often? Depends, eventually you can feel when it needs to be honed vs needs to be re-sharpened. Advanced, this is where you tell me. I have a few pointers and that's about it for advanced. Don't over sharpen, yes it happens. The blade will curl or chip depending on the metal. If it doesn't curl or chip and is over sharpened it will be very hard to control. It will slice so smoothly that you won't realize the blade is slipping past the surface you intend to skive, shave or cut until it's too late. Find quality metal, I tend to only use high carbon but I know someone will say they have razor sharp blades in stainless steel. If you do, please share the type of steel. My current sheath project is for a skinning blade made of 1095 folded with 15N20 and you can bet your socks I had to look up what 15N20 is so share your thoughts on steel. Also, what medium do you cut on and how do you store your blades. Durable mats and boards usually dull blades too fast and flimsy mats save your edge but fall apart too soon. Any decent middle ground? Storage, best ways to store blades so that they don't smash off of other tools and stay dry so they don't rust?
  6. Thank you, the knife is a layering of 1095 steel with 15N20 steel, I can't remember how many times it's folded, I believe it has 280 layers. Right now it's sharp enough to shave with but I will find out only through time how well it will hold up.
  7. Greetings from Nor'Easter region, It's been close to a decade since I did any projects but after getting a Single Action Army and a new skinning blade blank I've gotta dust off the cobwebs and see what I remember. I started on a Tandy beginners box set that was probably made for teens but after a few projects on some oak shoulders and scraps from a friend I started getting into it. Past projects where coin purses, messenger style bags, sheaths and a few whips, the stand out ones where the 8ft bull whip and the cat o' nine tails. Recently I acquired a SAA revolver and the holster I plan to make will probably be worth more than the gun itself, no offense H&R, she's a fun little .22 and I like her. I also found some new knife blanks that may or may not be the greatest but I've only had them a few days and they feel nice and they need a proper dressing. I've been a carpenter/woodworker my whole life so I have the handle ideas down but I will have questions on ideas for sheathing styles and patterns. Suppose since I will have enough veg tan left after the SAA holster I should make one for my 9mm but I may put that on hold while I try a run at a Tombstone replica rig for the single action. Heard rumor Doc carried double action revolvers in real life so I might not match the guns but I will try his suspender style rig, looks a little awkward but probably functions well, I do prefer a cross draw. I will post a picture of my first project because it's really how I started years ago, Tandy precut and all, also I will post the the two new items that need some new clothes. I will be asking a few questions here and there if I don't find them in the forum search. I think tonight I'm just gonna skim the forums and work on my Dubbin mix. Found some local beeswax from the same guy that sold me our Christmas tree and gonna put it to some use.
