antoniosewing
Everything posted by antoniosewing
  1. Hi Wizcrafts, sorry if I answer only now but I haven't been home. thanks to you, I managed to solve the problem. The first problem is that the height of the central foot was not well adjusted. the second problem was that I only understood later. is that the tip of the needle was in the right adjustment position when it came up and not when it came down. in that case I aligned my feet and solved it. I just have to adjust the pressure or maybe even the height. still marks leather a lot. thank you very much for the help!
  2. thank you so much for your help. "The tip of the needle and bottom of the inside foot should meet the top of the feed dog together" so I have to go down with the central foot in the case of the photo? through this right lever, if I understand correctly? (now I upload the photo in the next message) tomorrow I will try to follow your instructions and I will update you.
  3. Hi, this is the first time I write. sorry for my English. can you help me? I changed the classic foot set on my juki 441 clone machine. the height of the new foot was different and I tried to adjust it with the two screws that lock the bar. since. the foot is no longer alternate moving. Is there anyone who knows the procedure for making this adjustment? thanks in advance for your help.
