gkulpins
  • Content Count
    2
Everything posted by gkulpins
  1. Can I assume I will mist the surface with water and wipe it so no water remains on the surface prior to the first coat of dye application? Suggested sprayer? I was considering the Powermate Vx Gravity Feed Spray Gun. Does the tip diameter matter much for dye and resolene application? Do you think a 50/50 dilution for the dye would be acceptable? Do you dilute the resolene prior to spraying (I assume a water dilution as it is acrylic based)? Would two coats of resolene suffice? Thanks, Greg
  2. Hey All, Newbee here. I am planning on re-dying a Flexsteel leather couch. I have read that it is possible, it is not recommended, it is recommended, its worth it, and it's not worth it. A replacement couch would be ~$1500, so I figured I would give it a try before investing that. My plan is to use Fiebing supplies (deglazer, dye, and resolene). I intend to re-suff the seats prior to the re-dye. A few questions: 1. I will be dying a full size sofa (quite a bit more than a chair). How much of each product (deglazer, dye, and resolene) should I have on hand? 2. When prepping the surface with the deglazer, should a cotton rag be used, or a more aggressive applicator like a scotchbright pad? 3. Would you recommend the use of Fiebing's “Leather Dye” or the “Pro Dye” for a furniture application? 4. Is there a recommended temperature range for the use of your products (4 degrees here today)? 5. Do you recommend “casing” the leather after deglazing and prior to the dying process? 6. Would you recommend diluting the dye with denatured alcohol to allow for several applications to ensure a more even coverage without darkening too much? (my concern is after the applications of three coats of dye, the sofa may get too dark) I appreciate any and all comments. I have attached a photo to show where I am starting. Thanks a bunch, Greg
