drafthorses
Everything posted by drafthorses
  1. Looking for right way to adjust " thread Tension regulator" on Pfaff 26..... and should there be a center pin that releases the tension wheels when presure foot is raised?
  2. Thanks for the reply....your suggestion worked
  3. I have PFAFF 138 it was sewing properly and suddenly now jams up. It will travel to the top but not continue decending on the other side.... I think that the Needle bar is suddenly out of adjustment. It hits the top and will not continue. Will go down and go up on back stroke and stop at the top. Also the tip of the needle only reaches the top of thee Bobbin Any assistance on how to adjust??? thanks
  4. My apologies everyone.....my Pfaff is # 26
  5. Having problem with bottom tension when working with thick materials ????
  6. Need manuals for LANDIS "American 61" St Louis, Operating and/or service also Mfg date??? pic att, but poor quality thanks American leather sewing m.html
  7. In previous.... Likely is "American" s61.....leather stand up pedal sewing machine made by LANDIS Co. does anyone know manufacturing year???
  8. Does anyone have info on manuafcturer, age, of "Americana" s61 ...... stand up leather sewing machine. ?? pic would help thanks
  9. Thank you very much....I re adjusted the " Bobbin Case Stop Finger" and seems to stitches properly...just a few tension and stitch length to fine tune and should be sewing as it should...again thank you for your help
  10. Thank you very much....I re adjusted the " Bobbin Case Stop Finger" and seems to stitches properly...just a few tension and stitch length to fine tune and should be sewing as it should...again thank you for your help
  11. Thanks for your reply....all of what you mentioned appears to be ok...the problem is that the hook catches the needle thread and pulls it about 90 degree turn and when the thread goes to slip out of the part separating it and ready to catch the bobbin thread...that is where it jams up and will not slide any further to bring the bobbin thread to the top.. Sorry not up to date on part names.....just hobbist.
  12. recently acquired 107w1 does not release the needle thread when it meets the bobbin thread and continuing causes the thread to wind around the bobbin case base. base and case cleaned, bobbin in correctly........help????
