Serendip
Everything posted by Serendip
  1. Meant pigmented vs. semi-aniline dyeing. Basically, I'm totally convinced that the pattern has been embossed on a heavy layer of filler. I dissolved that layer while trying to remove markings. The grain leather itself has no embossing.
  2. Many thanks, mates! My previous couch had "natural" leather surface, and lasted for ages. I was a real fool by not paying attention to the texture and definitions right from the outset when buying this one. The manufacturer is domestic, and we tend to be trustful of countrymen (except professional salespeople). If this was only about dye vs. no dye, I would probably simply conclude that I will be smarter when buying leather goods in future. But this "plating" goes too far: can you really call that embossing? In my understanding, embossing is mechanical processing of grain structure, so the resulting texture should withstand, e.g., solvents. Isn't this more akin to "bonded leather"? On the balance, good to acknowledge that we might not be far away from what is typical in the industry. The manufacturer takes individual orders through furniture stores and ships directly to customers. I was suspecting that they might have engaged retail people to advice on how careful or smart the receiving end seems. That would have been an outright fraud. But it seems less likely now. Maybe the knowledgeable folks just ignore the promises and walk by after taking a look at the specimen. At least in this country, going individually to a civil court is not practicable. However, one law firm sought class action of consumers (not part of our legal tradition) against the tire manufacturer Nokian Renkaat after they had "cheated" on magazine tests (supplied modified non-retail versions of their products). Wouldn't lose anything by calling them.
  3. Hi Folks, My newish leather sofa had on it dye markings that I couldn't remove with leather cleaning solutions. So I tried diluted isopropyl alcohol that seemed to work with some rubbing. However, it also removed color and texture from the surface (see close-up photo). I was perplexed and sent the manufacturer a question how to fix this: they offered to send paint at a hefty price. While going through educational websites and ordering supplies, the bleeding obvious occurred to me: the material probably isn't semi-aniline leather as claimed. Solvent could remove some paint and lacquer, but it does not dissolve the leather itself. Furthermore, embossment is not mentioned, but the texture is uniform and has much bumpiness, which seems odd. A representative called me and sounded totally nervous as I pointed my suspicions: his explanation was that they may have "improved" individual spots by "embossment", and I may have hit such spot with wrong agent. So what do you think of surface material in the photo? Can it be painted leather, which would amount to false declaration of leather quality? Or did I remove some totally artificial coating, which would amount to a fraud? Thanks from a Newbie!
