cybernob
Content Count
6 -
Posts posted by cybernob
10 hours ago, nylonRigging said:Did you ask previous owner what size thread he was trying to run on the top thread ?
When he showed me he was using 69 as well and how it was threaded through the additional tensioner, still passed thru the original tensioner. He told me he used it to sew heavy marine vinyl for his boat and showed me how it sews thru 5 layers. Although the needle he was using was a 180 so I suspect you are right about 138. He told me he bought a walking foot machine so was selling this one. My guess is the DB did almost everything but made the mod and it didn't work.
I've threaded it using the additional tensioner rig and thru the original tensioner as he showed me but I can't see adjusting the tension on the additional making any difference to tension result at all. The balance isn't affected. Only thing that affects it is the original tensioner, I suspect this is because of the tension spring at the end of the additional tensioner and before the original tensioner is buffering the thread so there is no constant tension.
It may be there is no difference also because I only been testing on s single layer of vinyl and it doesn't need more tension which I suspect he was looking for the additional tensioner to provide. I think he had the right idea to spread the tension out but needs to bypass additional tension spring.
From what I can see using his setup there is no real fine grained control on the tension and therefore stitch balance.
So what I'm thinking of doing is bypassing the original tension spring and putting an adapter plate that will allow the foot lever to still operate the tension of the additional tension set. It means I can remove it no harm done. Crazy? But if it works I think it'll work really nice and give me a larger tension range. I've got some 138 here and will try it out as well probably on the weekend as I've removed the additional tension set to look at how to make the adapter plate and also I have to reseat the press fitting on it.
Yeah I'm not sure about the second tension unit. The person I bought it off was using it to do marine upholstery and must have added it for thicker thread but it looks like the original tension spring has been upgraded also.
I'm going to try and see if it makes any real difference to the stitch quality, still learning about this machine!
Thanks
Hey thanks for the quick reply I really appreciate it. It's my first industrial and I've slowed it down with a servo and 45 pulley and built a new table top for it.
Hi all,
just starting down the journey of sewing. I have a Mitsubishi DB-121 with 135x5 needle shaft but can't seem to find any information on the Mitsubishi DBs and history. Does anyone know what they are and the differences in the 12x models? Also is there an easy way to identify compatible parts?
G
Mitsubishi sewing machine info
in Leather Sewing Machines
Posted · Report reply
Thanks for the advice as you said they're cheap so I've got the missing thread guide coming to put it back to normal. I'll still experiment with the second tensioner as I have it just to learn more :). When I get more serious though I'll get a walking foot.
