CyberBadger
Everything posted by CyberBadger
  1. Here's some manuals & saved information that I was able to find, I'll try to upload any others I might have saved. The other file has some assorted photos, including some measurements of the bobbin/shuttle hook, a comparison between the one for my machine and the Singer 29k, as well as images of my modified 29k shuttle alongside the original one. There's also a few photos of the other shuttles that I received with the machine (they did not fit properly) and some measurements taken by the previous owner whom I suspect was trying to find a replacement. I cannot speak for how accurate they are, but I know how difficult this sort of information is to find. Universal Elastic - Claes - Colibri.zip Universal Elastic - Claes - Colibri Photos.zip
  2. Hey - I forgot that I ever posted this. I should be able to post the manuals I've been able to find. On my way to work right now but will try to check once I'm home. I'm not certain of the exact model I have, but in my case the problems seem to have been partially due to the shuttle hook being extremely worn, the tip seems to have been repaired with brazing at some point. However, I discovered that it is nearly identical in size/shape to the one used in a Singer 29k, save for a few distinct differences. With some minor grinding & polishing, I was able to retrofit a Singer shuttle & the machine works perfectly now. I am also working on a CAD file for the bobbin shuttle & can post a 3D scanned version of the original. Cheers
  3. Update! I feel a bit dumb now.... Thanks to the manuals, some photos and a helpful video on another forum, I discovered that the previous owner probably had the incorrect needle size. I lowered the needle by 5mm or so and it seems to work!! Now I feel a bit dumb... As I understand, the machine should take System 88 needles, so I have ordered some to try. And the shuttle is still quite worn, so I will see if the Singer 29k ones fit, as a few people reported having success. But otherwise this should work to start out with!
  4. PM sent, thanks! Hoping I can find the proper bobbin case somewhere if that's indeed the issue...
  5. Hi all - I've wanted to get back into leatherwork and recently picked up a small patcher with the intent of using it for smaller home projects. It seems to have been well-maintained, and was in use by an older gentleman until relatively recently. I believe it might be a Kochs Adler 'Universal Elastic' - at least 'Universal' is visible on the paint remnants. Unfortunately I'm worried I may have overpaid as I cannot get it working properly. I'm a bit limited with what's locally available as I don't have a car & I wanted something smaller that doesn't rely on electricity, but I'm hoping I didn't make a mistake here... I thought that it was just incorrectly threaded - but now I'm wondering if the bobbin cases are wrong. It came with 3 which are slightly different sizes. The darker coloured one is, I believe original, and slightly shorter than the other two. None of them seem to glide close enough on the left side to hook the thread. Any information or help would be greatly appreciated!
