NancyLou
Everything posted by NancyLou
Thank you AlZilla Indeed we will. We could not believe how much force it needed to get back into place. She is purring like a kitten. . Ron and I are happy it’s fixed. It was a stressful week. Thank you again everyone for the great suggestions. All the best
Thank you Dkman
If you are ever if Florida look us up. We owe you dinner. 😄
Thank you so much. What should we use to lubricate it?
Country Bob my friend. It took 4 hands and a lot of force but it went IN!
Thanks, Bob for all your help I did engage the shaft, but unfortunately, it did not move or change the position of the piece of metal that’s supposed to go into the slot see picture above even after moving the wheel towards me and or away from me
Photo 2 I believe that there should be a space between the outer wall and the plate but correct me if I am wrong. It seems stuck up there.
We pushed button. It is in gear. Shaft is moving perfectly but we still have the problem in the video. The little piece ( don’t know what it is called) is not going into the slot the way it is suppose to. It is just on the edge of it.
Thank you cowboy Bob and kgg. We did engage the button. That was the first thing the repair guy did. Fixed the button and engaged it. Then he went to clutch area and that is when everything stopped. He fixed and tweaked everything else but did not feel comfortable taking apart clutch. We have been oiling for two days. Here is where we are at. Thank you for any help.
Hi Bob This is Ron Nancy’s husband. Thank you for replying. I did watch the same video Singer Safety Clutch above several times. Here is the problem I’m still having. Any help will keep me out of the dog house 😂
Thank you Alzilla. As much as as love this machine I just wonder when I should say enough is enough. She has great bones but sometimes …….. The repair man John has fine tuned everything but when he got to this part he just was not comfortable with taking it apart. He doesn’t work on many 111W155.
Ok uploaded. Any help appreciated.
Ok let me see if I can do that. I will try to figure out how to upload to you tube. Hold please. 🙏
Does anyone know of someone in North Florida who can repair a problem. The shaft is not hooked up to the lower clutch. See videos. Pieces are stuck on the pulley. Thank you for any help. Mod Edit: (I removed the 240 meg attachment since it's now on youtube -AlZilla)
I’m sewing webbing onto a cast net using the singer 111w155 which is the only thing in my life that gives me a hard time. I just refilled the bobbins: everything was working up until I did that. It seems to go about 5 stitches then stops abruptly, and all the thread is bunched on the bottom. I have checked threading etc oiled but cannot figure out the WHY. Could it possibly be that there is too much thread on the bobbin? You all have help me in the past and I appreciate it. Is the only bobbin thread adjustment the bigger screw shown in photo? Frustrated in Florida
Thank you so much. Have a great day.
Does anyone know where I can find a needle for a Singer Ultralock 14U32. singer cat no 2054 size 10-14 serger locker Thank you Nancy
My son the engineer figured it out. I did not want to force it closed, but he said it was getting stuck up because it was a little bent. Anyways that solved. Thank you everyone for replies.
Thank you. I will try that. I did take the bobbin case out to see if anything was stuck inside spring. All good with that. I will check small the small pin next.
Thank you Glenn. I will look again. There did not appear to be anything last time I looked. I might need a magnifying glass as the little one I have is not good with my older eye.
Hello I have a walking foot Singer 111W55. The latch that you push down after you stick bobbin into bobbin case is stuck in a straight up position. I tried oiling and putting pressure on it to release but having no luck. Any help appreciated. Thank you Nancy
