5teve
Everything posted by 5teve
  1. Hi All As every google search about my issue seems to point me toward this site - I figured registering and asking may be the way to go. I dont work with leather just sunbrella etc for personal boat canopy use. I have a Jiahe sewing machine which is a servo (built in) digital clone of the typical GC0303 - I am using PTFE thread on my latest project (and polycarbonate) and have 2 issues. Issue 1, I cannot get the upper thread tight enough. I cant pull it by hand and its still not able to pull the bottom thread back through. The bobbin has its tension set so it drops down gently under its own weight. I end up with an almost flat bottom thread and the upper thread lopped totally round this thread. (certainly not buried half way into the material as it should be ideally) Issue 2, top thread is shredding. I have read a number of topics on this, it could be the way i am rotating the thread around the upper plates (flat ones with 3 holes in) could be the hook catching the needle, burrs on the hook or a million other things. It certainly seems to be worse on the higher upper tensions. Can anyone point me to a guide / videos about setting this type of machine up.. I would take it into a shop to get it set up, but i'm stuggling to get any kind of answer of availabilty from anyone local here in perth australia.. I'm normally fairly handy and have a go at most things and have what appears to be a mostly accurate typical GC0303 manual - unfortunately the machine i have seems to be missing some of the markings on various parts that the typical has! Any help would be greatly appreciated! Steve
