Members NatyTea Posted June 23, 2023 Members Report Posted June 23, 2023 Greetings, I just replaced my bell knife on my skiving machine, Consew DCS-S4, and I now have a new 5mm of new length of blade to the left (towards the left). Thus, the blade currently sits about 5mm *past* the edge of the presser foot. This would not be an issue if I could bring the blade back by turning the knob (see photo), but unfortunately I turn it, it turns the brass threaded shaft, but nothing else on the horizontal axis moves, so the blade doesn't shift from L/R. I was watching videos on maintenance/replacing blades, and one said the knob turned indefinitely. Mine does stop after a long amount of turns in either direction in case that matters. I've tried turning it to one of the ends OR the middle of the crank and installing the blade at those points, in case it has to be calibrated in some way, but that didn't work, so I didn't keep playing with this idea. Nothing I can see moves horizontally from the turning of the knob on the perpendicular axis. I know this machine used to be owned by someone who would skive THICK vegtan for sandals, I'm wondering if that might have done something to the components inside? Any thoughts greatly appreciated! Thanks! Quote
Members eddo Posted April 30 Members Report Posted April 30 Hi, I know this is a late comment, but I have exactly the same problem- did you ever resolve this? Thanks, Ian. Quote
Members mbnaegle Posted May 1 Members Report Posted May 1 For that style of main shaft, the brass piece is supposed to thread onto a steel sleeve inside of it. If the brass is turning but the steel isn't moving side to side, I expect the brass part is stripped. I see it has a Consew tag? I believe those skivers were made by Taking in Taiwan. I'm not sure who sells part for them. The design is very similar to old old Fortuna skivers, but I don't think the parts will interchange. Quote
