Members Dave9111 Posted April 27, 2024 Author Members Report Posted April 27, 2024 I finally got to test the new Groz Beckert Gebedur Titanium needles (134-35, #23 R) on the same machine (Pfaff 1245) with the same material and the needle thread shredding is no longer there. So that fixed the shredding issue. However, comparing the #23 Groz Beckerts to the Innova #22's that I have been using shows that the #23's are a lot bigger. Does anyone have the dimensions of a #22 system 134-35 needle? I don't care if its metric or imperial. I'm wondering if the #22's I have are undersized. I have searched for it, but its not popping up. #22 is stamped on the shanks of the Innova needles. I think Innova is the distributor. The individual packs of 10 only say made in Germany with a small logo. I've had these needles for a long time. Its a 100 pack. The #23 Groz Beckerts are noticeably cutting the threads in the material. The holes made are clearly shredded just a bit. This is on Weathermax 80 outdoor canvas which is a very tight weave fabric. I'm not sure if I should be concerned about that or not. I'm thinking probably not. When I run through two layers of Weathermax 80 with a Polyester binding, there is not noticeable tearing on the binding. The stitches look great. This was when the thread shredding became a real issue. I was occurring when just running through two layers of Weathermax 80, but adding the binding was a killer. The stitch formation also appears to be better with the #23 needles. So you guys were right. The needle was the problem. Thanks for the help! Quote
