Raulhs Report post Posted Wednesday at 09:16 PM EZ Edge Strap Beveler-used Located in San Bernardino, California You'll need to pick up the machine in San Bernardino, California. Used for 2 years, well maintained. In Excellent Condition Selling For $900 o.b.o. The convenient leather strap beveled machine allows you to edge all four edges of your strap at once for time savings and reduced labor costs. With 12 cutting blades (6 on each side), the blades can be rotated and switched to the opposite side, so you don't need to re-sharpen as frequently. The bottom blades can be dropped down if you want to only edge the top two edges. A hand-operated, thoughtfully designed machine will not reduce strap width. Whether you're edging one leather strap or 100, you need a reliable machine to get the job done quickly and professionally every time. Finished leather edges are a surefire way to elevate your leatherworking projects, and this strap beveler from our trusted Master Tool line is up to the task! If you're looking to save time and money and save your hand from fatigue, this leather strap beveler is the solution for you. Its convenient, hand-operated design delivers the consistent performance and quality you've come to trust from a machine bearing the Master Tool name. Accommodates 1/2" to 3" strap widths Rotating the blades and switching the side the roll is on helps reduce the need to sharpen as frequently. Set-up includes a set of four #2 blades Handmade In The USA Selling For $900 o.b.o. Quote Share this post Link to post Share on other sites
