Contributing Member friquant Posted February 14, 2025 Contributing Member Report Posted February 14, 2025 Is there a video on adjusting the hook to needle distance on a 545? After my original hook broke, I am installing an aftermarket hook and the new hook bumps into the needle so I'm adjusting. I have the hook saddle loose, but how to move the bevel gear so it still fits well against its mating gear? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members nejcek74 Posted February 14, 2025 Members Report Posted February 14, 2025 You can use Pfaff 1245 service manual: link Quote
Contributing Member friquant Posted February 14, 2025 Author Contributing Member Report Posted February 14, 2025 (edited) 7 hours ago, nejcek74 said: You can use Pfaff 1245 service manual: link This looks good. Here is the unfurled link in case anybody needs it: https://www.supsew.com/download/Pfaff/Pfaff 245, 1245; 246, 1246 Service Manual.pdf Pfaff 245, 1245; 246, 1246 Service Manual.pdf Edited February 14, 2025 by Northmount uploaded file Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Contributing Member friquant Posted February 16, 2025 Author Contributing Member Report Posted February 16, 2025 Here are photos of the Pfaff 545, since they are somewhat different than what the 1245 service manual shows. To adjust timing: loosen the two screws at A. To adjust hook-to-needle distance: Loosen the two screws at B (to move the hook saddle) and also loosen the two screws at D and the two screws at E (to adjust the new mating distance of the bevel gears.) As for the two screws at C, they do not need to be loosened. One of the screws at C is resting on a flat spot ground into the hook driveshaft, so that's why you have to use the screws at A to adjust timing. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
