Members Mechiel Posted April 30, 2025 Members Report Posted April 30, 2025 Acquired a second hand Adler 467 some time ago. I am in the process of getting the machine running and discovered that the supply line (pipe) is missing altogether. What I gather from the manuals I downloaded, thanks to this forum, this line gets its supply from the the hook shaft. It then goes through a non-return valve and routes via the sight glass to a brass pipe whereafter it feeds a small sump in the head. I am sure that one can make up this line adding the non-return valve. I am a bit lost when it comes to the I shall appreciate it if someone can direct me and even better send a photo or two on this. A further help would be the exact routing inside the machine via the sight glass. Quote
Members Mechiel Posted April 30, 2025 Author Members Report Posted April 30, 2025 Adding to above, I am a bit lost where this line/pipe is attached to the hook shaft i.e. the source where the oil comes from Quote
