Members ledburner Posted May 19, 2025 Members Report Posted May 19, 2025 (edited) Hi guys. This is my 1st post. I'm from the UK. I mostly sew outdoor gear in heavy codura or somilar. (I'm not a Thread Insertion Technician). This forum seems to be the closest rewarding sewing machines. I'm looking for advise on parts required (&source), or internal adjustments to be made to taken out play on the inner walking fit. When it is under compression it can shift sideways or rotate axialy. A 1mm (maybe 1/32") sideways . (Pictured below), This is with about with with several layer of canvas and or webbing.. is this machine repairable? Possible worn parts included... singer211G256 508281. vibrating presser bar with bell crank, (visible wear). 508295 Needle bar rock frame. Hopefully not needed The bushing linkage on the presser bar are also worn. Which is more accessible. Hence the rotation. The oil felt on the rocket bar frame has mostly disintegrated which may have caused excess wear. I have approached a few suppliers and have BD told it's discontinued (no suprise) and not available. Pictured (sorry I can't manage the picture order) worn oil felt presser bar play no load presser bar play under compression presser bar linkage no load presser bar linkage compression Also parts diagram & description Picture 1? worn rocker frame oil pad parts_serv.pdf parts_serv.pdfp211g_155.pdf211g_155.pdfparts_serv.pdf Singer 211G155, 211G156 Service ManualA4.pdf Edited May 19, 2025 by ledburner Quote
Members ledburner Posted May 20, 2025 Author Members Report Posted May 20, 2025 The1st paragraph had a few typo or autocorrect mistakes. If should have read. "Hi guys. This is my 1st post. I'm from the UK. I mostly sew outdoor gear in heavy cordura or similar. (I'm not a Thread Insertion Technician). This forum seems to be the closest regarding [upholstery] sewing machines. ) Quote
Members ledburner Posted May 21, 2025 Author Members Report Posted May 21, 2025 Has any one got any advise please? Singer 211G256? Thanks in anticipation Dan I'll try to post a video. Quote
