Members StevenMoore Posted January 21, 2009 Members Report Posted January 21, 2009 I have a question, not sure if its a real question or not. I have a tacsew that has an internal oil system. The machine came with the clutch motor and would run at a high RPM. Since I installed a servo motor with four speeds including real slow will the oil system still work correctly running at the slow machine speeds? Should I run the machine at fast speeds for a few minutes (without thread) to run oil through the system, then slow it down? Or am I just over reacting and it should be ok as is? Steve Quote
Bree Posted January 21, 2009 Report Posted January 21, 2009 StevenMoore said: I have a question, not sure if its a real question or not. I have a tacsew that has an internal oil system. The machine came with the clutch motor and would run at a high RPM. Since I installed a servo motor with four speeds including real slow will the oil system still work correctly running at the slow machine speeds? Should I run the machine at fast speeds for a few minutes (without thread) to run oil through the system, then slow it down? Or am I just over reacting and it should be ok as is?Steve It will run fine. I wouldn't give it a second thought. The machine will let you know if it's thirsty for lube. I suspect that most of the lubrication is accomplished through wicking rather than the force of the machine. If you are uncertain, call TacSew. They will give you the definitive answer. Quote Ride Safe! Bree 2003 Dyna Wide Glide Memberships: Iron Butt Association, Niagara Falls HOG, Wild Fire HOG NRA, Niagara County Sportsman's Association
