Hey, no problem Jed. I started out with a book and endless supplies of rawhide. Several cows gave their lives, only to end up as chew toys for the dog!!
As for your question, I leave the leather collar in the kot. It is the foundation, and without the foudation the knot will work loose.
I braid with my strings just wet enough to work, so there isn't really alot of shrinkage. I braid my knot, roll is or pound it, I usually just slide them off and hange them with the others, but you can wait till it drys if you want too. It won't shrink so much that you won't be able to get it off.
Don't feel bad about asking questions. There are a lot of awesome braiders on here, I've learned form everyone, so if you don't understand something, just ask. Hopefully one of us can explain it.
~Luke
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
~Luke
Thanks!... I appreciate it!
Jed
"You have to give somthing you never gave to get somthing you never had." ~Ray Hunt~
I've run into a bit of a problem, the piece of leather underneath is to big and shows on the sides. Fixing that problem probably comes down to practice. Now I can see how important it is to hide the ends right because your knot seems to hang over the edge just a bit to hide the leather underneath.
Yeah, you'll have to do a couple to figure out exactly how to cover it. you'll get good at interweaving in order to fill up the knot a little bit.
Charlie- I use about a 9/16" mandrel. It works well.
I'm bringing this back up..hopefully rawhider or someone else that does these slides will see it. I finally got one done that I like, an all whiskey gaucho. Anywho my question is, have you ever wrapped it with a little wax string when doing the herringbone to give the slide a more rounded look?
I've never done that. I just bevel my egdes on the foundation really extreme, and it seems to work for what I like. But there is no reason why it wouldn't work for you. You can really do anything you like to underneath the knot, just so long as it doesn't come apart after you start useing the slide.
Well I'm running into a bit of a problem because I don't have cowhide so I'm working with very thin kangaroo for the foundation. What I did is wrap the tape a few times and that seemed to do the trick and give it a nice shape...But sadly I still have to use glue because the braiding just doesn't wrap around the foundation like it would if it was a thicker piece of leather. I still like it much better than the way I used to do it, so thank you very very much!
You could build up the foundation with several layers of your 'roo. Using the cement, glue one on top of the other. You can make the top pieces progressively narrower and end up with an ovoid shape rather than a straight collar.
