Randyc Posted May 17, 2009 Report Posted May 17, 2009 I'm working on my first IWB holster and planning to use T-Nuts and screwa to attach the belt straps. The holster is a 2 piece design made from 6/7 oz. cowhide. The belt straps are also 6/7 oz so I' looking at 18-21 oz. total thickness. I will be using "durable duty" Line 24 Snaps. Whats the proper size/length of T-nut and screw size to use? Whats the best way or tool to use to set the T-nut prongs into the leather? Thanks, Randy Quote
Contributing Member TwinOaks Posted May 17, 2009 Contributing Member Report Posted May 17, 2009 When I've used them, I punch a hole just a little smaller than the shaft of the t-nut, then stretch it out to intall the t-nut. Several times I've needed to clip the points of the prongs to keep from over penetrating the holster. For setting them: a good hard surface, and mallet. Oviously, if the t-nut is longer than the holster is thick, you'll want to use something to allow for that. I'm pretty limited on my selection of hardware (homedepot/lowes) so I've been using the 6/32 size. Just be sure to allow a spacer between the belt loop straps and the holster, and figure that into your thickness. Quote
Lobo Posted May 18, 2009 Report Posted May 18, 2009 Randy: I use similar weight leathers for my IWB holsters. I use a two-prong Tee-nut with 6-32 screw, length 3/8", when setting the snap base through 2-layer wings on the IWB. Hole punch of approx. size for the shaft of the Tee-nut, set the T-nut with a mallet, mount your belt strap with snap base and screw, done deal. Your local hardware stores may be slim on Tee-nuts and screws, as those around here are. I buy in bulk, and have several hundred sets on hand. If you need a few for a single project or to experiment with, drop me a PM with your mailing address and I will send you a few sets. Happy to help if I can. Quote
Members 10mm Posted May 18, 2009 Members Report Posted May 18, 2009 As Twinoaks said, I sometimes have to trim the prongs on the T nut so that it wont over penetrate though the layers of leather. As far as a setting tool, I bought several fender washers from Home Depot and glued them together. I forget the actual size, but the inside hole just needs to be big enough for the T-Nut collar to fit inside. I put this under the leather and tap the T nut into the leather. The washer setup gives you a good base to set the T nut and allows clearance for the collar while giving a solid base to set the prongs. Quote
Randyc Posted May 20, 2009 Author Report Posted May 20, 2009 Hey guys, thanks alot for the information. Ray (Lobo) is nice enough to be sending me several sets of T-Nuts so I will know what size to start buying. Randy Quote
