Ian Posted March 12, 2008 Report Posted March 12, 2008 When you're painting the background (black background on tan) on a sheridan carving, how do you keep the black from getting onto the raised area when you apply the finish? I don't like any of the spray can finishes and usually use Bag Cote or Leather Balm applied with a small scrap of towel. Thanks Ian Quote
Members Nocturne Posted March 12, 2008 Members Report Posted March 12, 2008 Try these on some small scrap/practice pieces.. I would try waiting a full 24 hours for the background to dry before trying any type of finish or protective coat. Once it's had enough time to dry, it shouldn't bleed any. If that doesn't do the trick, then since you're not using spray finish, try putting a thin coat of your finish on the background area first, let that dry, then finishing your entire piece. Quote
