Dear all, sadly I have pierced a leather piece in an area where it should not be.
Do you know a way how I can make a stitching awl whole nearly invisible ?!?
I was thinking about coloring some leather flour, mix them with glue and put them into the whole ?!?
I appreciate every single hint.
THX in advance.
Cheers,
Marcel
FKA adamant-leather
Feel free to visit my site adamant-leather.de
Nice thing about an awl hole is that it CAN be closed.
IMO, you need to wet the hole and allow the leather to swell back into place. Flexing it should help the fibers 'get back in position'. A thin glue can be used to seal the hole closed (careful about not getting glue on the surface) once it's dry. If you can, stamp/stitch over it because the puncture in the grain side will be visible as a small line.
Just my take on things, someone else may have a better solution.
Mike DeLoach
I'd go with Mike, Marcel. Just wet the leather and squeeze and flex the sides of the hole together. When it is all back in place give it a 'gentle' tap with a shoemaker's hammer and you should find the hole vanishes.
Good luck,
Ray
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
Hi Guys,
thanks for the hint. I will try it out.
@UKRay
Short off-topic. Thanks for the Skidmores cream...It works really good, had no brittle shoulder straps since using it ;-) Hope everything is fine with you !!!
Cheers,
Marcel
FKA adamant-leather
Hi Marcel,
Glad the Skidmore's Leather Cream worked out well for you. Its amazing stuff.
How did the hole work out? Did you manage to make it vanish?
Ray
Ray Hatley
