Talonzz Report post Posted August 19, 2009 While rummaging thru the local antique shops back room I found an old treadle sewing machine... the machine looked to be in good condition, but the Wooden case/table was shot to he77... I asked the guy how much he wanted for it, being a cabinet maker I figured I could re-build the cabinet. He told me $20. Has anyone had any experience with these old gems? I know they are used alot in the quilting circles. I would be using it to sew together moccasin weight leather and thinner. I figure if most people are hand cranking the motorized machines anyway... why pay for the motor? and with a treadle i can crank the machine and still use both hands to guide the material thru. A couple of links: http://www.scripophily.net/davsewmaccom.html http://www.ismacs.net/davis/davis_walking_foot_machine.html http://sewwonderful.blogspot.com/2008/09/d...tical-feed.html Quote Share this post Link to post Share on other sites
Cobra Steve Report post Posted August 19, 2009 Talonzz, this machine will be better served as a conversation piece. It is truly a collectors item. As I recall, it had the long bobbin that traveled front to back, not at a radius. You should not try and "fix it up" or polish, paint or clean with chemicals. This will drop the value of the machine. That's all I can tell you. Thanks, Steve Quote Share this post Link to post Share on other sites
Talonzz Report post Posted August 20, 2009 Thanks for the Response Cobra Steve... and the Info Quote Share this post Link to post Share on other sites
