Members xlr8tn Posted October 24, 2009 Members Report Posted October 24, 2009 I just purchased a few edge creasers. I have an Osborne Edge Creaser #1 and just picked up #2 and a double edge creaser #2. Trial and error...#1 is just too thin and tends to cut the leather. I am making watch straps and often see this decorative crease on the edges and the stitching either on the inside crease or in between the creases. Although this tool seems simple enough to use, can someone give me any tips on the usage of this tool? Am I supposed to heat the tool to sort of burn in the crease? Am I supposed to wet the leather (mostly gator and cowhide)? Any help would be appreciated. -Brent Quote
Contributing Member rdb Posted October 24, 2009 Contributing Member Report Posted October 24, 2009 I've always called it a Push Beveler. Lots of people call it a creaser...either way is okay, but by calling the old fashioned name, at least people might understand how to use it properly. Many people pull it back towards themselves...don't. Push, and keep it as straight up as you can without sliding off the edge. That allows for the rounding part to be more effective. I always burnish the edges first, before using it, makes for a smoother ride along the edge. I still heat mine up on a small propane torch, but others don't. They case the leather properly, then use the tool. That makes a fine impression. With it heated (not to much now), I think it seals the bevel nicer, and glides smoother on the grain...each to his/her own. Quote Web page Facebook
