Members HDL Posted December 11, 2009 Members Report Posted December 11, 2009 Does Vinegaroon cause any side effects when used on holsters? Like rusting the gun? Does it leave an odor and what top coat do you use? Tim HDL www.highdesertleather.com Quote
Contributing Member TwinOaks Posted December 12, 2009 Contributing Member Report Posted December 12, 2009 Hi HDL, I've used 'roon on several holsters and sheathes with no ill effect. That said, I'd like to mention that my 'roon is rather old, and the acetic acid (vinegar) has been completely reduced/used up. There's still a little odor to it, but it's not a vinegar smell. If you have any question about the PH of the leather, you can make a baking soda + water solution and dunk the holster to neutralize any remaining acid. I've also used ordinary tap water to rinse it. In a nutshell (which, incidentally, can be used, but that's another thread) the vinegar eats the metal producing Ferric Acetate. The ferric acetate reacts with the tannins in the leather, producing gray or black (and sometimes the prettiest blue, depending on the tanning method). As long as there's vinegar active, it'll have a vinegar smell. Once the vinegar smell is gone, so is the vinegar. Keep in mind that leather actually does better with a slightly acidic PH. If it's TOO acidic, that can effect the finish on blued guns or steel in the white. I usually don't use any topcoat on the 'rooned holsters/sheaths. The reaction inside the leather tends to push the tallows to the surface, giving it a pretty good moisture resistance. In fact, part of the 'rooning process is oiling the leather to get some conditioning BACK INTO the leather. Instead of oil, I typically use Aussie conditioner and rub it in really well. Heat helps the leather absorb it. On the handful of occasions I've used a top coat, I used leatherbalm to give it a little extra shine. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members HDL Posted December 14, 2009 Author Members Report Posted December 14, 2009 Hi HDL, I've used 'roon on several holsters and sheathes with no ill effect. That said, I'd like to mention that my 'roon is rather old, and the acetic acid (vinegar) has been completely reduced/used up. There's still a little odor to it, but it's not a vinegar smell. If you have any question about the PH of the leather, you can make a baking soda + water solution and dunk the holster to neutralize any remaining acid. I've also used ordinary tap water to rinse it. In a nutshell (which, incidentally, can be used, but that's another thread) the vinegar eats the metal producing Ferric Acetate. The ferric acetate reacts with the tannins in the leather, producing gray or black (and sometimes the prettiest blue, depending on the tanning method). As long as there's vinegar active, it'll have a vinegar smell. Once the vinegar smell is gone, so is the vinegar. Keep in mind that leather actually does better with a slightly acidic PH. If it's TOO acidic, that can effect the finish on blued guns or steel in the white. I usually don't use any topcoat on the 'rooned holsters/sheaths. The reaction inside the leather tends to push the tallows to the surface, giving it a pretty good moisture resistance. In fact, part of the 'rooning process is oiling the leather to get some conditioning BACK INTO the leather. Instead of oil, I typically use Aussie conditioner and rub it in really well. Heat helps the leather absorb it. On the handful of occasions I've used a top coat, I used leatherbalm to give it a little extra shine. Mike thank you for the response, I am going to give it a try. Tim www.highdesertleather.com Quote
