Members Luthiel Posted December 26, 2009 Members Report Posted December 26, 2009 Hi, I'm wondering if anyone has any ideas/patterns for leather armor for my nephew. He's only 5, so it's obviously just for looks rather than protective value. I thought about some form of scale or lamellar armor, but I'm concerned that it might be too heavy. Any suggestions? Quote
Members troy Posted December 27, 2009 Members Report Posted December 27, 2009 Hi Luthiel First time I made armour for my youngest he was about 7 years old (photo below shows another set made for my 9 year old) I used 3-4mm tooling leather for them and hardened it slightly with beeswax altho for a 5 year old just wetting it and letting it dry will stiffen it enough probably - your notice I went for the plain chest pieces made popular at the time by the film troy - scale armour would mean adding alot more weight to the whole thing so using thinner tooling leather might help. rather then using the method descibed in my tutorial - http://blog.mtn-m.co.uk/__oneclick_uploads/2009/11/leather-armour_l.pdf - it might be better if you use an old t-shirt of his (which would be better it slightly too big for him)to get a pattern from. Hope this advise helps Paul Quote
Members Luthiel Posted February 3, 2010 Author Members Report Posted February 3, 2010 Hi Luthiel First time I made armour for my youngest he was about 7 years old (photo below shows another set made for my 9 year old) I used 3-4mm tooling leather for them and hardened it slightly with beeswax altho for a 5 year old just wetting it and letting it dry will stiffen it enough probably - your notice I went for the plain chest pieces made popular at the time by the film troy - scale armour would mean adding alot more weight to the whole thing so using thinner tooling leather might help. rather then using the method descibed in my tutorial - http://blog.mtn-m.co...er-armour_l.pdf - it might be better if you use an old t-shirt of his (which would be better it slightly too big for him)to get a pattern from. Hope this advise helps Paul Thanks! Quote
