oldcowpoke Posted January 20, 2010 Report Posted January 20, 2010 Comelz 4 Thermo-Cementing and Folding Machine Price $2500. Thermo-Cementing and Folding Machine for uppers, leathergoods and automotive interior trim. COM 4A is a machine used to perform an even and finely finished edge folding: it folds both open and fully closed uppers <LI>it can insert a topline reinforcement. The pleating and snipping facilities make it easy to obtain evenly folded curves and avoid any distortion of the work pieces. The efficient thermo-cement distribution unit provides for a precise and stainfree adhesion. PRACTICAL A functional and efficient work area is the essential condition to reach maximum output. On COM4A the wide accommodation of the hands and the excellent visibility provide for optimum working conditions; all controls are grouped in logical areas and can be easily reached by operator, who can comfortably make all adjustments without using any tool. PRODUCTIVE The most important features which enhances the performances of a folding machine are the work feed rate and the reduction of downtime to a minimum. On COM4A, the rotation speed adjustable up to 2,400 rpm, joined by a wide range feed pitch adjustment, provides for very high processing speeds. The guide system, which provides for 3 to 7 mm adjustable folding width by simply moving a lever and without any part replacement, makes the feeding of the workpiece easier, thus reducing unproductive time. VERSATILE COM4A can be fitted to perform any special folding work: <LI>french style (binding) <LI>flat insoles <LI>leathergoods <LI>automotive interior trim <LI>roll top finish. Optional fittings are easy to assemble and the operator himself can change them in a few minutes. FUNCTIONAL COM4A features a homogeneous design; both electric and electronic parts, as well as mechanical parts, are integrated into the basic structure and divided into independent and functional units. Large covers provide for simple maintenance: the inmost parts of the machine are readily accessible. Quote
