Design S021010
Please keep in mind that unless I ask for anyones critique I do not want nor require same.
HI Storm;; Cool design ;;;where will we see it on a project????
Howdy Storm
Good looking pattern. I was looking at your beveling. I notice that you have leaves below your swirl. I see that the second leaf, you started beveling on the outside, then continued your beveling into the stem. I would have started my beveling on the out side and stopped at the stem, then started my beveling on the bottom of the top leave and continued it down into the same stem. That leaf is part of and a continuation of the top leaf. I may have also back grounded the area inside the pattern that you left with no background or dye. I would give flow to your back grounding.
I would have also used the same type of veiner on the small swirls as you used on the large swirls. Just use a smaller tool.
That's just what I would do. Looks good, keep up the good work
Tim
Edited by TimKleffner
It's hard to fail, but worse never to have tried to succeed.
Theodore Roosevelt
Design S021010
reminds me of Fractal patterns
Cheers
Mike
Thanx. I have a more advanced version I want to use on a journal cover. If I create it I will post it.
Storm
Cheers
Mike
Thanx Mike,
I guess when you look at it with another pair of eyes it has a Mandelbrot sort of feel to it. HA!
Storm
Very nice. I like it. Good job.
Making Leather Projects.
Thanx much Deno.
