Members Travis The Red Posted April 19, 2010 Members Report Posted April 19, 2010 Hey everyone, I bought these celtic border stamps from tandy last week and I'm having a terrible time making my impressions. They came with a set of instructons that say to only use the stamps along a scribed or cut and beveled line only. I don't really know what this means because I've never used stamps before where I had to do anything extra to get them to work properly. If anyone can explain to me what exactly these instructions mean or just might know what im doing wrong, I'd really appreciate the help. Quote
Members wildrose Posted April 19, 2010 Members Report Posted April 19, 2010 I also own the set. I've had alot of trouble with them. It's one of those "good concept, poor execution" things. I believe the point of the directions is that it's easier to line them up properly if you scribe a line to follow first. I used them to make a border on a guitar strap. Customer was happy, but I truly wasn't. I've only used them on very small pieces since. Quote Holly Moore Wild Rose Creations http://www.wrcleather.com
Members whinewine Posted April 20, 2010 Members Report Posted April 20, 2010 I also own the set. I've had alot of trouble with them. It's one of those "good concept, poor execution" things. I believe the point of the directions is that it's easier to line them up properly if you scribe a line to follow first. I used them to make a border on a guitar strap. Customer was happy, but I truly wasn't. I've only used them on very small pieces since. Trav: a problem is that the impressions aren't very deep, the knot lines are very close together & the stamps are large in area, which means that you'll need a heavy maul/mallet to make a decent impression. All too often one ends up making a double impression because the stamp may bounce after being struck if the leather is too dry. I also have a set & they are definitely NOT the easiest to use, but once you know their limitations, the results can be ok. Like Holly says, they're primarily good for small pieces. Quote
Members blade Posted April 20, 2010 Members Report Posted April 20, 2010 i have them and have little to no problem useing them but it does take a good blow and dont let them bounce. soon as i get home next mouth ill take some pics Quote
Contributing Member UKRay Posted April 28, 2010 Contributing Member Report Posted April 28, 2010 I don't have too many problems with bounce, but I tend to case my leather really well before I start stamping - I find this helps a lot. My real problem is lining the wretched things up. As they are so 'square ended' any discrepancy is a glaring error and look horrible. I have started using another stamp between sections to conceal the irregularities LOL Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members KProffitt Posted February 5, 2011 Members Report Posted February 5, 2011 Use an Arbor Press with the stamps. Quote
Members Temugin Posted February 14, 2011 Members Report Posted February 14, 2011 Its like everything in life the more you practise the better you get ... I found them difficult at first , lining them up and getting slightly out bothered me , also bouncing off when the print wasn't deep enough . They ain't the easiest stamp to work with but do look good when you get it right .. Quote
Members budd4766 Posted February 14, 2011 Members Report Posted February 14, 2011 I've started using a good heavy dead-blow hammer when I have stamps that normally tend to bounce. I found the dead blow cuts way down on my double impressions with stamps like this, and some of my bigger, stamps, maker's mark, or 3D stamps. Quote
