Members gregintenn Posted June 19, 2010 Author Members Report Posted June 19, 2010 Yep, . . . got that one right, . . . When I read the post, . . . I envisioned gregintenn sewing each loop together as it came through the hole, . . . just goes to prove that even without glasses it sometimes isn't easy to read what is written. Stitching on each end could be most appropriate, . . . depending on what look was desired. May God bless, Dwight Yeah. I meant the ends. I'm not a fan of rivets. Quote
Lobo Posted June 19, 2010 Report Posted June 19, 2010 Here is a photo of the set I refered to above. You can see the single line of stitching on the cartridge slide where the loops are terminated at the end. On a belt there will be plenty of additional room to get creative with the stitching. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members gregintenn Posted June 19, 2010 Author Members Report Posted June 19, 2010 Looks good, Lobo. I want to make some of those cartridge holders for high powered rifle cartridges as well. I like the way that one looks. Quote
Members JackRabbit Posted August 17, 2010 Members Report Posted August 17, 2010 (edited) Hey guys , do you have the same problem as I do ... after punching the holes in thick leather with the bag punch they are widening up towards the surface , like ... V ? Only the behind of the belt has that 1/8" oblong slot topside slot being much wider. Do you have the punch sides reshaped or what is the way to get the slots formed straight ... well , at least not so wide on a top . ( My idea to try is to moist the areas between slots and bone them flat with the boner , sounds any good ??) JR Edited August 17, 2010 by JackRabbit Quote Fast is fine but accuracy is final .
Members JackRabbit Posted August 17, 2010 Members Report Posted August 17, 2010 Answering to my own question : Yes , the boning works . My buddy had asked me to make a cartridge slide for spare ammo for his .38 . Today when back home I took a strap of thick leather and drew the lines for punching the holes for a ammo slide and taking the bag punch I whacked a row of slots into leather . Got the V - shaped slots as usual ...but then I moistened the areas between the slots , then boned them to re-flatten the leather for straightening the V's into I I - shaped slots. Went just fine . I dryed the leather with the warm-air blower and did the weaved loops for 38 Specials . Had very neat and TIGHT loops all the way . JR Quote Fast is fine but accuracy is final .
