oldskool
Creaser - Looking For Advice
Hello, I have tried a couple different creasers with differing amounts of happiness on my part.
I have tried the basic plastic one that comes on the end of the plastic burnisher/creaser/folder you can get at Tandy:
http://www.tandyleatherfactory.com/home/8116-00.aspx
That one actually works well, but the pressure and repetition required to get the crease I want ends up melting it and flattening it down so that it is not usable.
I picked up a metal version that is adjustable:
http://www.tandyleatherfactory.com/search/searchresults/8072-00.aspx?feature=Product_2&kw=creaser\
I found it terrible to use because it was not as reliable, predictable and controllable as the plastic one.
Also, I would like to be able to make a double line crease at one time. So, what out there will give me results like the plastic version, but last longer? Also, what out there has the option for a double crease?
I have one of those groovers, but I am not interested in removing surface leather, just burnishing a crease into the leather at the edge.
