RandyScott Posted August 9, 2010 Report Posted August 9, 2010 Does anyone tips on how to avoid this problem? The suggestions to use a round knife is because the width of the blade, 4" - 6", makes it very easy to see when the blade is canted from the vertical. My mentor, with about 60 years of experience, has several head/round knives however he uses an 'angled utility knife'. He has three or four scattered around the cutting table. Here is a link to the Tandy product he uses: http://www.tandyleat...ture=Product_26 . Ergonomically it fits the hand well, therefore more 'controlled' power can be used to make a single cut through 8 - 12 ounce leather. And, keep that blade polished and strop often to keep that razor edge on the blade. His work is predominately on large stuff, knife sheaths and holster/gun belt rigs. I personally found that if I position my work light to shine directly down the line of cut toward me, then I could also use the shadow of the blade as it fell on the pattern to assist me in keeping the blade vertical. Just as in sawing wood with a handsaw, body position is very important in keeping the blade vertical and learning that comes with practice. Some of the posts segued toward the Damascus blades, lot of money for a knife. I picked up two very nice and older CS Osborne head knives with 4" - 4.25" blades for less than $30 each plus shipping via EBay. Might want to try a less expensive tool to determine if you want the more expensive version. It took me a while before I was comfortable with my fingers anywhere close to those razor sharp head knives. I made very sure my fingers were behind the cutting edge. I still use them occassionally, however, I now use my angle utility knife for most cutting as I find it easier to control the cut and I can put more power into the cut. Quote Complacency Kills
Lobo Posted August 9, 2010 Report Posted August 9, 2010 Now that everyone is all excited about round knives I'll add a comment or two. In my shop we use heavy-duty scissors, specifically the Kobalt 9-1/2" Multi-Purpose model sold at Lowe's for about $25.00. With only a little practice these will provide very detailed and clean cutting of up to around 10-oz. veg-tanned. 6/7 or 7/8 is pretty easy to cut for anyone with moderate hand strength. My first pair of these is about 2 years old. During that time I have touched up the edge twice with a diamond sharpening steel. The second pair has been in use for about 4 months with no sharpening needed. In perspective, we are turning out about 1500 items per year, so this is very low maintenance indeed. I can cut about 8 holster patterns per hour with these. My apprentice is doing a dozen or more per hour. She does this work while sitting in a comfortable chair, listening to the radio, enjoying a cold drink, rather than standing over a work bench and trying to keep track of all her fingers with knives. After assembly and stitching the edges are dressed with a sander, then beveled, and burnished as part of the finishing process. The results are excellent. Now, rough cutting is a different matter. After marking out several patterns on a side of leather I use an electric sheet metal shear to cut around each one, setting it aside for detail cutting with the scissors. With this method I can have a dozen patterns roughed out of the hide and ready to cut in about 30 minutes. So overall cutting time for a holster pattern is about 7 to 8 minutes, which I doubt can be beaten by much with any knife work. Keeping things simple works for me. Best regards. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members Deanimator Posted August 9, 2010 Author Members Report Posted August 9, 2010 Now that everyone is all excited about round knives I'll add a comment or two. In my shop we use heavy-duty scissors, specifically the Kobalt 9-1/2" Multi-Purpose model sold at Lowe's for about $25.00. With only a little practice these will provide very detailed and clean cutting of up to around 10-oz. veg-tanned. 6/7 or 7/8 is pretty easy to cut for anyone with moderate hand strength. I think you're definitely onto something here. As I believe I mentioned, I tried using my grandmother's 50+ year old seamstress's shears, but they need a good sharpening. I got my tuckable M1911 IWB done this weekend, and for the most part managed to get pretty straight edges, which I cleaned up with a Dremel and sanding drum on a router speed control to keep the speed down. I'll definitely have to give the Kobalt's a look since I actually walked past Lowe's today when I was out for exercise a couple of hours ago. Thanks. Quote "When I was young, I looked like Al Capone but I lacked his compassion." - Oscar Levant.
Denster Posted August 9, 2010 Report Posted August 9, 2010 Hey Lobo! Thanks for the tip. I had to go to Lowe's this morning to return some excess roofing material. Went to check on the scissors and Lowe and behold they have them for $9.98. I have to cut patterns this afternoon and if they work as well as you say my poor old carpel tunnled wrist will thank you aslo. Quote
Members cstephens Posted August 9, 2010 Members Report Posted August 9, 2010 Ok I'm off the Damascus high but now I wonder about a new sensible knife. Are the new Osborne knifes worth the money? I can't stand to watch and watch on eBay to finally find a good knife only to be outbid by $2.00 because they snipe me. I did buy 3 pairs of wiss industrial low leverage scissors for 2 bucks each but I want to learn some more traditional ways as I am a more hobbiest then a businessman. Any suggestions for a decent priced quality knife for a beginner? Quote S.C.L. Stephens Custom Leather - College Station, TX Whenever you are asked if you can do a job, tell 'em, "Certainly, I can!" Then get busy and find out how to do it. - Theodore Roosevelt
Members Deanimator Posted August 9, 2010 Author Members Report Posted August 9, 2010 (edited) Hey Lobo! Thanks for the tip. I had to go to Lowe's this morning to return some excess roofing material. Went to check on the scissors and Lowe and behold they have them for $9.98. I have to cut patterns this afternoon and if they work as well as you say my poor old carpel tunnled wrist will thank you aslo. I bought the last pair my neighborhood Lowe's had today. I need to get a bunch of holsters made for next month's club swap meet so they're going to get a workout.. Edited August 9, 2010 by Deanimator Quote "When I was young, I looked like Al Capone but I lacked his compassion." - Oscar Levant.
