Members Garange Posted September 6, 2010 Author Members Report Posted September 6, 2010 Two holes and then A) use very sharp chisel or B ) a carpet cutting knife to cut the slots open . If you use carpet cutter , do not try to get through with a single cut . Good way to avoid blade marks in the ends is to start the cut from the hole and meet at center o =><=o . For sanding take a 0,5 or so strip of aluminium or plastic . Then attach the sandpaper on it with two-side adhesive . Now You have a "leather rasp" in your use . For the icing on the cake , use thin bone stick and burnish the sides of the slots . My o o : s JR Thanks for the reply and advice.. I use a 3/16" hole punch for either end, draw straight lines between the edges of the two holes, and cut along the lines with a hobby knife. Then I burnish the slots with gum trag and the end tip of a deer antler. A slot punch would be nice, but daaaaaaaang those things are expensive!!!!!!!! Thanks for the help. I think I'll get a hole punch and start there. Gary Quote
