Members boom Posted November 17, 2010 Members Report Posted November 17, 2010 Hey i need to make a belt for a guy like this one. i figure ill need two layers of leather but does anyone have a pattern or template for the top curvy part? Total width of the belt will be 1.5 inches. Thanks! http://www.rods.com/Stockyards-Rawhide-Belt,1170.html Quote
dirtclod Posted November 18, 2010 Report Posted November 18, 2010 You could make a pattern pretty easy i think. Cut a piece of poster board the width you want them. Draw a center line. Then draw a circle and and come off of it like in the picture. Draw a diamond and do the same thing. Cut both out. Line them up ( 2 or 3 of each ) spacing to where it suits you on a seperate piece and cut that out. Then cut a piece of poster board the width you want mark a center line on it. Line center lines up and mark then move and mark again till your done. Quote I'm old enough to know that i don't know everything.
Members boom Posted November 18, 2010 Author Members Report Posted November 18, 2010 You could make a pattern pretty easy i think. Cut a piece of poster board the width you want them. Draw a center line. Then draw a circle and and come off of it like in the picture. Draw a diamond and do the same thing. Cut both out. Line them up ( 2 or 3 of each ) spacing to where it suits you on a seperate piece and cut that out. Then cut a piece of poster board the width you want mark a center line on it. Line center lines up and mark then move and mark again till your done. Thanks! Quote
