Members 8KCAB Posted December 8, 2010 Author Members Report Posted December 8, 2010 Thanks for all the replies, guys and gals. Here is some input I recieved from another (pretty well known) source: I know some braiders use a needle. I would really learn to use a fid. Don't worry so much about the fid technique until you know where to go in braiding the button. The only reason for not setting the fid down is so you do not have to straighten your string as much(and improves your speed), which would just as true with a needle. Once you can do a button easily, then concentrate on your technique. A needle has more set up time, is slower, tougher to use when button is getting tight towards the end. You can't put leverage on a needle without breaking it. Also, you still need a fid to tighten the knots. Also, one big problem is that if a braider sweat very much and you have long project, the needle discolors the leather. There's a million ways to skin a cat. I've been branding calves since I was a kid - but if I go to a new ranch someone's gonna want something done a different way. I know I'm getting ahead of myself on this stuff - I'm just starting to get my 6 Bigh Turks Head straight-ish. I don't fly as much at work as a used to since I recieved a "promotion", so I have lot's of time to waste on the computer. It makes it look like I'm working - otherwise I'd be fiddling with strands at my desk! Just out of curiosity, does anyone know how the old Californio's did it? I'd guess that needles were pretty scarce. Maybe some kind of fid or awl fashioned from local hardwood? Any idea's about the techniques of Luis Ortega? Again, I don't think there's a right or wrong way. This braiding bug has piqued my curiosity about the historical factor. Quote
Members miguelm Posted December 16, 2010 Members Report Posted December 16, 2010 hello, for fine braided knot is essential to use a fid. I learned the technique of Gail Hought.Is irrelevant for simple knot (5-6), but for a ( 9-10) is very important. Miguel Marcos http://www.secretosdelcuero.blogspot.com Quote
Members 8KCAB Posted December 16, 2010 Author Members Report Posted December 16, 2010 Thanks, Miguel! I'm glad you joined this forum! Are you close to the Pyrenees? My wife's from a little village in them on the French side. Quote
