hello all.
i received my new Osbourne head knife, so i decided to make a sheath to protect it.
this was my very first project involving stamping and stitching.
first, i traced the knife blade on a piece of cardstock. then added about 1/2" to it for stitching.
then i use a stitch groover for the stitching border, then for the inner pattern border.
i punched the stitching holes using a 4 prong 8066 punch and stamped it with the x502s triweave stamp.
after stitching was complete with waxed thread, i used an edge beveler and burnished with gum taraganth.
then i used eco-flo "Briar Brown" to stain it, followed by Dark Brown Edge Cote.
i really need to find a better way to punch holes for stitiching. i had a difficult time lining up the holes of the two leather pieces...
i think it turned out ok for a first try. some of the stamping was a bit off, but i can live with it. i think i need more dye practise too.. :yes:
be gentle with me... its my first time! :blush:
  On 1/5/2011 at 8:54 PM, almac said:
hello all.
try gluing the edges together first before punching holes
If a job is worth doing at all, it is worth doing right
I think this is a must first project for anyone with a head knife! Just a suggestion- I can still see some of the knife when you have it in the sheath. Might want to make another and seat the blade a little deeper. Adding a strap to it would be good, also. Keep up the good work!
Crystal
In addition to gluing the edges together, try an awl instead of a 4 prong punch.
Crystal
the blade can go all the way in, i just didnt push it all the way in for the photo. :whistle:
i had a tandy awl, but the thing broke the first time i used it. :head_hurts_kr:
after that, i went to the 4 prong chisel.
looks great. If I were to have made it, I'd add little "tabs" behind the spines of the blade and put snaps on them to keep the sheath on the blade.
I would recommend (so you dont make the mistake I did on my headblade case) dont use only one strap. I made mine with only one strap, and when I travel to classes and what not the blade can slip out the side the strap is not on.
Dan
"A wolf wins every fight except one, in that one he dies"
Nightwolf
