Hi all,
I have made a couple hats. One is a top hat and Im not sure what the other one is. It looks ok for the most part. But the problem I am having is getting everything in sync. I have made several patterns and have studied what I could find here and at other websites about making hats but my circles just don't match up with the brim or the top of the hat. I always have either a gap or excess at the top, bottom or both. I guess I am asking, What is the math formula for measuring to make a hat?helpsmilie.gifHow do I get the measurement for an oval? I hope there are a few elementary math teachers on here crazy.gif
Thanks!
  On 1/30/2011 at 6:00 PM, Menolly said:
Hi all,
Thanks!
Not an elementary teacher, but... :coffeecomp:
Circumference of CIRCLE= 2 x Pi x radius OR diameter x Pi
Pi= 3.14 (approximate)
RADIUS= 1/2 the diameter, (the measurement from the center to the edge of the circle)
OVAL: for exact measurements, you'll need calculus. However...
OVAL: simple measurement=
measure the short radius and measure the long radius
double both the sr and the lr
square each of the results, then add both together
divide by 2
take the square root
multiply that result by 2Pi (2 X 3.14) :party26:
Hope this helps a bit.
russ
Even with math, you may be of some due to rounding up/down, etc. How do you make your patterns. and what are they made out of?
Also search hat, and top hat here. Someone just posted some patterns, etc.
You laugh at me because I am different. I laugh at you because you are all the same.
divide by 2
russ
oh my...head_hurts_kr.gifI didnt think it would be THAT complicated lol. Thank you for taking the time to share that with me, Russ. grouphug5vj5.gif
Hi Bigundoctor,
I made up my first pattern after researching the various types and bits and pieces of patterns I found on the net. I looked at cloth hats a lot to see if they explained how it was done too. For my second hat I used a pattern from Leatherlearn. It was an old Tandy pattern I think. I printed it out then traced it onto file folders for a more permanent pattern. The first hat I did was way to small for most people so I wanted this one to be larger. I think that is where I went wrong. I tried to make it bigger and didnt really know what I was doing. I just didnt know if there was a trick I am missing to make this easier. Obviously it isnt using math formulas. At least in my case! I don't have a calculator with a square root button on it for starters. lol
Thanks for the suggestions :D
Ellen
This is where a computer can come in handy. If the pattern is on your computer you can enlarge it to any size you want, and print out the larger pattern. I blew up an old Al Stohlman picture of a flying eagle that started out around 2", and ended up with it being 18" or so. ended up taking up 5 sheets of printer paper to get it all.
Even without the math, patterns can be made with basic stuff like string. Wrap a piece of string around your head, that is the circumference. You can make some big calipers out of cardboard to get the width, and length of your head. Then do this http://www.mathopenref.com/constellipse1.html
Hope this helps, and remeber :google0dw:
What about a dress makers cloth tape.
I'm old enough to know that i don't know everything.
That is what I would use. I just wanted ti illustrate the fact that you don't need anything special to do this. I have some of the old Foxfire books, and the folks in the Appalachians didn't have anything fancy, but they did some neat work none the less.
