Hello! Okay I admit it, I'm a super new-guy. I really want to wrap my steering wheel, shift boot and shift knob with leather, and I've been reading and studying all over this forum and some others for a while, so I decided to get started with the knob. It's a billiard ball that I drilled and tapped a hole into. When I fit the leather onto the ball I realized it needed to get stretched a whole lot in order to get into that hemispherical shape I want. I want to have two hemispheres of leather that I can then stitch together with some thick, white polyester thread. My question is this: what do I do from this point to get my hemispherical pieces? Should I glue it down to the ball and then "eyeball" about half way down and cut it with a hobby knife? Should I not glue it, but cut it off about half way and place it flat on the table and make another round piece of leather the same size? Ideally I want to be able to mark the underside with carefully measured marks and then make holes with an awl before stitching. I want to be as precise as possible for this whole project. What would you guys do? Thanks in advance!
post-19849-051702700 1298065268_thumb.jp
measure the ball and mark the equator on it instead of eyeballing it. Then start stretching leather around it until you can cover the mark. Leave a little room, you can always trim it later. As an additional hint.....get any of the balls 9 or higher and measure the stripe, and mark the middle of it. That would be easier than measuring and marking the 8 ball.
Mike DeLoach
Hmm... that seems like it would work but if I mark the pool ball directly, that won't work because you have to have some extra leather to pull the leather down onto the ball with, which will cover up the marks I make on the ball.
Measure and mark the equator on the ball, stretch and form the leather, cut to fit. Once the half-a-ball is formed, mark a stitch line equidistant from the edge. Measure the circumference of that line and calculate the best SPI then mark it with wing dividers. Make holes with an awl. Repeat. Assemble the two halves around the core, and sew them with a curved needle. Finish as desired.
Mike DeLoach
Thanks
You could also do it like a baseball, Stohlman's book on cases shows how to do these.
Funny that you are covering a billiard ball, as they are usually left so you can see it.
You laugh at me because I am different. I laugh at you because you are all the same.
Yeah it's the shape and weight of the billiard ball that is desirable to me, and the feel of leather. So many people have an "8-ball" shifter that it's just been done to death and doesn't seem very creative to me. Where's this Stohlman's book you're talking about?
Hmm I'm having a lot more trouble with the measuring and the marking than I thought I would have. You see, the ball needs to be held perfectly, and I mean perfectly, to within a fraction of a millimeter straight vertical. If you deviate even a hair, when I mark the ball sides it gets all crooked. In other words marking the ball all the way around the equator is impossible so far. It's as if I would have to mount the ball on a spindle and spin it, in order to make a straight line right down the exact equator.
If you can't find the center line of the stripe on something like the 9 ball, you could always just roll it through a medium that will stick to it like chalk dust.
Or
Do you know the size of the ball? Standard size for the U.S. is 2.25 inches. Cut a hole in a board that size. Put the ball in, and when it's at it's tightest fit that's the center point.
Mike DeLoach
The leather case books are available at your local Tandy Leather store. I got mine second hand from someone who was getting out of leather.
I would drill, and install a threaded insert into it first.This will have to be dead on center too. If you know someone with a metal lathe, a milling machine, or a height gage it would be easy to scribe the center down to .001"-.0001" depending on what method is used . Plenty close for stretchy leather. I am a machinist, so to me this is an easy option for me.
A friend in high school had a buddy who put a tanned deer scrotum over his shifter. The girls liked it up until they found out what it actually was.
Take the shifter knob, and form the leather over it. 2 times so that you have 2 halves formed. Bore a hole in a piece of wood, or other suitable material so that the leather wrapped ball stops at its equator. Take a knife, and trim the leather off flush with the board. Repeat. It is better to be a little short, as the leather can stretch to fill a small gap, and pull tight onto the ball. Another option would be to lace it up, and the lacing will cover a larger gap, and form a grip ring around the shifter knob. Yet another option is to trim it tight, and just glue it on without stitching. Do a decorative overlay on the seam.
