Members Saddlebag Posted February 20, 2011 Members Report Posted February 20, 2011 The fenders have been shortened, the rivets are in, looks good. Well, sort of. I flipped the saddle over to try to find out why one leather won't budge eve after I'd had them running back and forth reasonably well, and I discovered lumps under one skirt that don't belong there. The saddle has had very little use. I think I'm going to have to umdo the skirts half way back to see what's there and even with a good pad this saddle could sore up a horse and maybe turn into a bronc. The skirts are linde with teddy bear fuzzy fabric and have been nailed in with steel nails which are already rusting and lI expect the staples will break when I try to pull them. Grrrr. This is becoming a reconstruction job. I now need to email the owner with a few pics to get her approval or not. Quote
Hennessy Posted February 21, 2011 Report Posted February 21, 2011 The fenders have been shortened, the rivets are in, looks good. Well, sort of. I flipped the saddle over to try to find out why one leather won't budge eve after I'd had them running back and forth reasonably well, and I discovered lumps under one skirt that don't belong there. The saddle has had very little use. I think I'm going to have to umdo the skirts half way back to see what's there and even with a good pad this saddle could sore up a horse and maybe turn into a bronc. The skirts are linde with teddy bear fuzzy fabric and have been nailed in with steel nails which are already rusting and lI expect the staples will break when I try to pull them. Grrrr. This is becoming a reconstruction job. I now need to email the owner with a few pics to get her approval or not. where are the bumps located.sounds like a hurry up n get r done factory job wot with staples n all.could be a broken bar,possibly no channel on one side and inhibits free leather slide around bar. good luck post your findings i'm curious pete Quote
Members Saddlebag Posted February 22, 2011 Author Members Report Posted February 22, 2011 My patience wore thin waiting for a response so I pulled the flooring nail at the gullet, which was already rusting, and half a dozen staples just to free up the skirt a bit. The big lump is where the stirrup leather bends around the tree near the air channel. The strap is a hair under 1/4" thick. I pulled some of the strap into the air channel and try as I may I can't get it to bend how it should. I'd have to soak it and beat it with a big maul but then it would never be adjustable. The next step is to remove the strap and run it through the splitter to shave it down a little. Even the slider on the blevins buckles are a tight fit which makes it difficult to change holes. I plan on replacing the nails with good brass screws and better nails. The skirt has in-skirt rigging which means the rider is unknowingly relying on staples and nails that rust and break. Quote
Members Saddlebag Posted February 27, 2011 Author Members Report Posted February 27, 2011 The owner has approved the extra work so the straps have been thro the splitter a few times. It will be ready to go home tomorrow.. Quote
