Does anyone have a clue where I can find a Kahr CW9 dummy gun? Rings doesn't have one and I looked at Duncan's list, but they don't have one either. Any ideas? Unfortunately, I am in NY and can't just borrow the gun :thumbsdown:
JRC,
You can find one at ......www.e-cost.com. Go to the "search" and put in "asp red guns" and you will find it there. Semper-fi Mike
"The first one thru the door...gets the copper-coated candy".
ADL Custom Holsters
"I've got a LONG list of real good reasons, for all the things that I have done"!!!
Thanks! I took a look and unfortunately, it's not the same gun. The one they have is the P9, which has a slightly different dimensioned slide. Just enough that they are not compatible. Luckily I am moving to S.C. late summer and won't have this kind of problem.
  • 2 weeks later...
I don't know how much detail you put in your molding but a P9 should work for a CW9. I've used the CW9 for a P9 client. The only real difference in the two is the scallop cut on the front half of the P9 slide. The width and height of the slides are the same.
I bone my holsters pretty tight, but if they are that close, I can probably fill the scallops with epoxy to get them close. Thanks for the info!
