Members jlaudio29 Posted April 7, 2011 Members Report Posted April 7, 2011 Finally got around to making a open carry rig for my Kimber Pro Carry II and a much needed gun belt. This was my first attempt at making a gun belt. Its two strips of 7/8 glued together then Hand stitched... yes hand stitched.. took me 5 hours to stitch, Next time it will be quicker because im going to do 2 seperate stitchings for the top and bottom instead of one continous run where in on the first side i end up dragging through so much thread through every hole. I made a few other mistakes along the way, the stitching on the backside isnt as straight as id like but that is the result of a few mistakes that will be corrected on the next one. I also ran out of die and really needed a second coat to have it match the holster exactally, its just a hair off, but the rig is for myself so im not worried about it, if it was for a customer i would have ran right out and go some more dye. Well here are the pics. Comments and questions are always welcome. Quote
Contributing Member TwinOaks Posted April 7, 2011 Contributing Member Report Posted April 7, 2011 Looks pretty good, but I advise against cutting or tooling any design into the border areas of either holster or belt. It makes for a cleaner look. Also, just my personal preference on this one, but I think adding some antique or highlighter to the cuts would make them stand out more....be more decorative. As it is, it kinda looks like brown on brown plaid. Over all a very nice job, but you may want to carry the sweat shield a little higher on the next one to include the BTGS as well as the slide. Thanks for sharing your work with us. Quote
Members katsass Posted April 7, 2011 Members Report Posted April 7, 2011 (edited) Finally got around to making a open carry rig for my Kimber Pro Carry II and a much needed gun belt. This was my first attempt at making a gun belt. Its two strips of 7/8 glued together then Hand stitched... yes hand stitched.. took me 5 hours to stitch, Next time it will be quicker because im going to do 2 seperate stitchings for the top and bottom instead of one continous run where in on the first side i end up dragging through so much thread through every hole. I made a few other mistakes along the way, the stitching on the backside isnt as straight as id like but that is the result of a few mistakes that will be corrected on the next one. I also ran out of die and really needed a second coat to have it match the holster exactally, its just a hair off, but the rig is for myself so im not worried about it, if it was for a customer i would have ran right out and go some more dye. Well here are the pics. Comments and questions are always welcome/quote] ********************************************************************************************************************************************************************************************** Good morning jl, from the grumpy old man: Looks pretty darned good, but just a couple of comments. As TW has said, I prefer to see a more definite treatment around your decorative work, and one not cut into with your decorative cuts. More of a 'frame' for your enhancements. Just a simple cut, maybe 3/8" to 1/2" in from the outer edge and beveled down. I don't do much tooling anymore or I'd have a pic of what I mean. One thing for holsters however, never cut along the fold of the holster when doing this, just allow the design disappear behind the fold, and try never to make a vertical cut of any sort along that fold. I can't see your edges very well, but I also prefer to round over a bit more and burnish, sometimes with dye, to set the edge off to a greater degree. Something like the edges in the enclosed pic. I made a comment in another thread on my opinion of reinforcement on the mouth of a holster, especially a concealed carry holster, and generally I don't use them. They can be, and are generally IMHO, used as a visual enhancement to your work, but if used should be 'set off' a little more. In use, thay aren't really practical, IMO. The only reason there is a small one on my avenger style holster is that it is a nice way to finish off the belt loop (second pic) and not seem to be just chopped off. Over all, still a nice piece of work. Keep it up,. Mike Edited April 7, 2011 by katsass Quote
Members jlaudio29 Posted April 7, 2011 Author Members Report Posted April 7, 2011 Thanks for the input, it is much appreciated. Quote
Members katsass Posted April 8, 2011 Members Report Posted April 8, 2011 (edited) Thanks for the input, it is much appreciated. jl; This is a pic of some work I did over 30 years ago..........while I was still learning (I'm still learning).........it isn't all that great, but it shows what I mean by 'framing' your work. A simple cut, beveled down, then your carving, stamping etc. inside of that, will set it off and display your work to it's best. . Hope this helps a little. The pic is not too good as it is a digital taken of an old 35mm print, and the piece was unfinished. Mike Edited April 8, 2011 by katsass Quote
Members jlaudio29 Posted April 8, 2011 Author Members Report Posted April 8, 2011 Thanks, yah i understand what your saying, ill have to try some that way, i personally like the holster the way i did it, but i think framing could add a lot to it and im still learning so always open to suggestions. Quote
