Members james m Posted August 11, 2011 Members Report Posted August 11, 2011 Hi there, I'm just starting out and was wondering, what order do you finish off a piece? After you've cut out all of your pieces and marked everything out do you assemble all of it then dye it and finish it and then do the edging or dye it then assemble it and do the edging after that? Thanks Quote
hidepounder Posted August 11, 2011 Report Posted August 11, 2011 On 8/11/2011 at 2:33 PM, james m said: Hi there, I'm just starting out and was wondering, what order do you finish off a piece? After you've cut out all of your pieces and marked everything out do you assemble all of it then dye it and finish it and then do the edging or dye it then assemble it and do the edging after that? Thanks James, Here's a good thread to read regarding edges. EDGES Hope this helps.... Bobby Quote
