Members Guy W Posted August 29, 2011 Members Report Posted August 29, 2011 What would be the best glue to use for glueing a pancack style holster together before stitching? I was considering Gorilla Glue but thought I'd see if there is a better type for use with leather. Thanks Quote
mlapaglia Posted August 29, 2011 Report Posted August 29, 2011 What would be the best glue to use for glueing a pancack style holster together before stitching? I was considering Gorilla Glue but thought I'd see if there is a better type for use with leather. Thanks Contact Cement. I use Weldwood brand. Coat both sides, let dry and put together. Make sure you have it lined up before it touches. Once it is in place it will not be easy to move it you can do it at all. The other thing I have used is Leather weld from Tandy. It looks like elmers but is a strong bond. You need to clamp it and let it dry. I prefer contact cement. Michael. Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members Shooter McGavin Posted August 29, 2011 Members Report Posted August 29, 2011 Make sure it isnt water based. I use pliobond contact cement simply because its what the local hardware has. Quote Zlogonje Gunleathers
Members Rayban Posted August 29, 2011 Members Report Posted August 29, 2011 Another Weldwood user here, gel formula......you can find it at Lowes and Home Depot. Quote Raybanwww.rgleather.net
Contributing Member TwinOaks Posted August 29, 2011 Contributing Member Report Posted August 29, 2011 Weldwood. I bought the little bottle with a brush in the cap, then I bought a quart in the can. I refill the little bottle from the can, and I've had it for quite a while now. Spread it as thin as you can on both pieces, let it get tacky and press together. This does require exact placement, because once it's set up a tack and put together....it's done. You can also put the pieces together while it's still 'wet' and have a little bit of wiggle room, but not much. Once this stuff dries, you'll actually be destroying leather fiber to get it apart. Avoid getting it on you, and have good ventilation. If the leather starts talking to you, put the glue away and move to fresh air. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
wizard of tragacanth Posted September 7, 2011 Report Posted September 7, 2011 A trick to use with contact cement to get the parts lined up is to use wax paper. I used to do this when I was laminating Formica to MDF. Coat both sides as usual. When they are ready to bond, cover the bottom piece with wax paper. Set the top piece on and line it up as you want it. Now, slightly lift one edge of the top piece, maintaing your position, and fold back a corner of the wax paper, exposing part of the bottom piece. Carefully maintain your lined-up parts and let the top piece settle gently on the exposed piece. I say gently because if it is not lined-up, you have a chance to pull it off. Once you are satisfied that it is lined-up, press the top piece hard enough to bond to the bottom piece. Be careful, don't trap the wax paper in there. Let's say you had "U" or "V" shaped parts. Do the top end of one side of the U, then expose the other top side of the U and bond that side. Now you can slowly slide the wax paper out, walking your finger down the edges and bonding them as you go. That's just an example, do it the way it makes the most sense or is the most appropriate for your situation. I hope that made sense. Nick Quote Nick
Members billymac814 Posted September 7, 2011 Members Report Posted September 7, 2011 I use Weldwood too although last time I ordered Masters from Springfield because I had to place an order anyway, it's about the same as Weldwood and costs twice as much. Is anyone thinning the Weldwood, if so what are you using? Quote www.mccabescustomleather.com
Members Steven Kelley Posted September 8, 2011 Members Report Posted September 8, 2011 I use Weldwood too although last time I ordered Masters from Springfield because I had to place an order anyway, it's about the same as Weldwood and costs twice as much. Is anyone thinning the Weldwood, if so what are you using? I've thinned Weldwood using the generic Cement Thinner from Tandy. There isn't any identification as to what the thinner is on the packaging, but I suspect it's MEK. Quote
Members marine mp Posted September 8, 2011 Members Report Posted September 8, 2011 Tandy's leather glue. Cheap and works great. Semper-fi Mike Quote "The first one thru the door...gets the copper-coated candy". ADL Custom Holsters "I've got a LONG list of real good reasons, for all the things that I have done"!!!
hidepounder Posted September 8, 2011 Report Posted September 8, 2011 Barge, Masters or Weldwood! Quote
