It's an OWB for a J-Frame. Aside from not knowing how to space the stitch lines (thanks to katsass for clearing that part up) I also had major movement of the right side belt loop tab when I wet molded. In the second pic you can see it moved or angled up about a half inch! How can I insure that the tabs are perpendicular after molding?
Edited by markush
I'm pretty sure that's caused by the deformation of the nice 2D pattern by sticking a gun in it and making it 3D.
I struggled with the very same thing with sweat shields and belt slots on Avenger holsters.
You might do what I did - learn from the experience and......
Note to self: on the pattern, move the right belt loop down 1/2 inch.
HaHa you know, that was actually the first thing I thought of...and if it moved straight up a 1/2" I'd just redraw it and be happy. But, it angled itself skyward all goofy :crazy: and I was hoping there would be a less...mcgyverish way to fix it. Looking at my quick rendition of the "corrected" pattern you'll understand why I was hoping there would be a better way.
I'd have to start with something like this...and surely the professionals don't do it this way do they? B)
Edited by markush
Too radical.
MUCH more of an angle than necessary to correct the minimal change in angle.
Also, it completely fails to address the simple vertical shift.
Just keep that tab more-or-less horizontal, but move it down on the pattern about 1/2 inch.
About even with the stitch line corner, I think.
I did draw it a little overboard to illustrate. But it actually did angle up more then you can see. I was able to straighten the angle of the tab somewhat after molding by trimming it a bit. But thank you! I will drop that tab and give it a slight angle and see what happens.
From the grumpy one: Just why do you insist on making yourself extra work? Ever since the Civil war folks been making great wearing and working belt holsters with a simple fold-over integral belt loop. Big un's, long un's, little un's, short un's and fancy or plain un's. It just don't make a hell of a lot of sense to me ..... ain't knocking it ....just don't understand it. Mike
P.S. You sure that you got cant on that thing right?
Edited by katsass
NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!!
At my age I find that I can live without sex..........but not without my glasses.
Being old has an advantage.......nobody expects me to do anything in a hurry.
Now that you mention it.....it does look a bit too close to vertical for a crossdraw......
IF...it's a cross draw ..... and it ain't going to conceal well eitherl. Mike
Edited by katsass
Yeah crossdraw. It's as much cant as I could do and not run into the belt loop with my knuckles on the draw. The gun was supposed to sit down into the holster another 1/4", improper stitch spacing stopped it from going any farther.
It was my very first holster guys, I'm still learning. It actually conceals fairly well with my extra large gut.
As to not making a fold over...I figure if i'm making it for myself I may as well try to make something I like the looks of and I wanted an easy on and off, not something I had to weave onto a belt. And besides, I've never been one to go along with the crowd...it doesn't matter that it may be eaiser or more "acceptable"...I try to do my own thing. But then of course I run into problems like with this holster...but hey, at least I can say I tried to be creative!
Edited by markush
That is some VERY nice work for a FIRST holster! Well done.
You might also consider a variation of the Avenger design, getting creative with the belt slot and belt tunnel locations. I've adapted it to an SOB design, and it worked well. Not too sure about the crossdraw, though. I did make one dual-carry Avenger design, that caught a LOT of flak on here. LoL
