walletman
Help With Singer 29K
post-6093-084600100 1316445535_thumb.jpgpost-6093-058422300 1316445493_thumb.jpgpost-6093-030678400 1316445440_thumb.jpg
HI ALL
How do i get the shuttle off ?
as there are something under it
and its catching as you turn the handle
i think i need to get to a pin ?
but not shore how to get to it
its a singer 29k53
any help many thanks
bob
hi there,i removed mine by taking the pinion box out with shuttle to get to the screw,turn the machine onto its back,remove the two screws covering the pinion box the turn your wheel until the block on the driving pinion is at the furthest point on top(this makes returning back to same position easier)then slide out the long rack towards you after this all you have to do is remove the two securing screws and wiggle out the pinion box and shuttle,hope this helps you.
