Chavez
Combining Dyes With Different Base.
Hi!
Could somebody please tell me if it is ok to use acryllic paint together with fiebing's oil-based paint?
I am thinking of dyeing the leather piece with fiebing's saddle tan and then dyeing some parts of the pattern with red acryllic paint cut with water. I then plan to finish it all with resolene (hopefully not smudging the acryllic paint all over the pattern.
Does this sound like it may work or should I not try to combine different bases?
Thanks!
I think you'll be 'okay' with that process as long as you let the oil dye dry completely before putting the acrylic on it, but keep in mind the acrylic paint will only be on the surface. Paint is not a dye and doesn't penetrate the leather the same way.
Also, since the acrylic paint is water soluble, you're going to have to spray the resolene in multiple light coats to avoid dissolving it, which results in runs.
