When doing inlays do you sandwhich the inlay between two pieces? Or is it just stiched to the underside of the piece that is getting the inlay? I am thinking of doing a holster with some inlay work.
Thanks
Here is a little inlay practice piece that I did for my blog. The address below will be the beginning, but just click on 'newer' post to see the rest of the threads for the inlay project. I hope it helps you understand how it works.
http://kingsxcustomleatherworks.blogspot.com/2012/01/practicing-applique-work.html
Good luck
Greetings from Central Texas!
The Grain Side Up blog
#TheGrainSideUp
Good luck
Thanks!
